Weird IAT sensor problem
Old Mar 3, 2013 | 05:18 PM
Default Weird IAT sensor problem
Well did some logs today and came across a weird problem with my IAT readings. During cruising it worked just fine but when I got into boost it would go all wacky and say negative numbers sometimes and then say like 1* and soon as I get out of it, it would return to normal operation. I have a screw in sensor from RPS and it has been working great until now. Can the pressure be screwing with the readings? Thanks,
Nick
Old Mar 3, 2013 | 05:46 PM
You sprayin meth on it?
Old Mar 3, 2013 | 06:20 PM
Should've added that, no meth, just pump 93 and 14psi
Old Mar 3, 2013 | 06:58 PM
TURBHOE's Avatar
Is it an open filiment type? If so maybe the pressure is shorting out the sensor.
Old Mar 3, 2013 | 07:57 PM
I was thinking the same thing, this is the first time it's done it though. Here is a link to it Fuel System Parts, GM Air Temp Sensor, WW-GMAT | RacePartSolutions.com
Old Mar 4, 2013 | 04:10 AM
TURBHOE's Avatar
That's probably what is happening. Something wrong with the filiment and under boost it getting a direct connection (short) inside. Out of pressure it relaxes to its normal state. Easiest way is to try a new one. Mine is a stock syty one from napa.
Old Mar 4, 2013 | 06:36 AM
Yea that's what I figured. Im going to get another one and see if that fixes it. Thanks
Old Mar 4, 2013 | 11:09 AM
UnVmy5.3's Avatar
Does anyone know the part number for a thread iat sensor?
Old Mar 4, 2013 | 06:27 PM
TURBHOE's Avatar
Syty from napa
Old Mar 4, 2013 | 06:29 PM
TURBHOE's Avatar
Originally Posted by TURBHOE
Syty from napa
Su107 from autozone. They usually have them in stock or can get them next day.
