Wastegate venting
Old Mar 4, 2008 | 01:08 PM
t_thall's Avatar
On my old car i had the wastegate dumping out the passenger fender - didn't sound that great. It's less backpressure for the exhaust but i wouldn't do it again.
Old Mar 4, 2008 | 02:20 PM
1BadAction's Avatar
Registered abuser
Originally Posted by BlackGMC
Sorry to side track the thread, but can you plump the BOV somewhere so it is not noisy? I have seen a couple that vent to atmosphere and some others that can vent to a tube or hose...
Back to the inlet side of the turbo.
Old Mar 4, 2008 | 02:22 PM
BlackGMC's Avatar
Resident Retard
So between the Airfilter and turbo? Would that cause problems or does it help keep the turbo spooled?
Old Mar 4, 2008 | 02:25 PM
1BadAction's Avatar
Registered abuser
Yep, APS Seems to like doing it that way, all their kits I have seen are like that.
Old Mar 4, 2008 | 04:01 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by ZZebes
Right around 10.0:1 to 10.2:1 depending what the heads cc to
That's probably a little high for 9 psi without methanol.
Old Mar 4, 2008 | 04:12 PM
ZZebes's Avatar
We shall see
Old Mar 4, 2008 | 04:13 PM
thunder550's Avatar
We shall see
Ok, but I don't want to see any threads from you about
Old Mar 4, 2008 | 04:16 PM
ZZebes's Avatar
No promises, but i have dreams of a forged 370 in my head when this one gives up the ghost, i wonder how a stock motor would handle 15lbs
Old Mar 4, 2008 | 04:17 PM
thunder550's Avatar
Well when you put it that way, I think you should find out
Old Mar 4, 2008 | 04:55 PM
parish8's Avatar
single digit dreamer
it is usualy easier to vent the wg to atmosphere. how loud it seems kinda depends on how loud the rest of your exhaust is. to me it is like open headers once the wg opens but that is only when you floor it and after the boost level is reached. it wont be loud unless you floor it. i am prety sure you would gain power. maybe just a hp or two but maybe a lot more. it is like puting on a bigger down pipe. i can tell you the first time i floored my truck with twins and open wg's i was next to a concrete wall and it scared me with how loud it was but after the first time i expected it and it didn't seem so loud.
eventualy i got tired of the sound and ran a seperate exhaust set up just for my wg's. i did like it a lot better quiet.
