Wastegate Spring Problem?
Old Dec 5, 2010 | 03:50 PM
05stepside's Avatar
Question Wastegate Spring Problem?
So last night I installed a 14lb spring and Blackbear was tuning it this morning. When we made the WOT pulls my boost gage was reading 16 and of course I let off the gas.
1st thing: How can I fix this? Get back to 14.
2nd thing: If there isn't a reasonably cost efficient way to fix this... should I get a 3bar sensor? How much do these cost?
Old Dec 5, 2010 | 04:06 PM
Mort's Avatar
Maybe go down a spring size?
Rig up an adjustable control like the STS boost control. I got mine for $50. Good for base spring pressure -15 psi.
Turbosmart makes a good and inexpensive boost control.
http://www.turbosmartonline.com/
Old Dec 5, 2010 | 07:04 PM
1BADAZZSS's Avatar
Experienced this problem before with smaller springs? Size wastegate and brand, what color is spring, and WG vented back to DP or atmostphere?
Old Dec 5, 2010 | 10:51 PM
05stepside's Avatar
When I first became fi I had a 67mm turbo and a 10lb spring but only read 8 then I went to a 76mm and got the full 10. This is my first time to change the spring. The wastegate is a 38mm tial and the "14"lb spring is blue. The wastegate is vented in the atmosphere.
Mort... I thought about the controller and that might be what I have to do.
Old Dec 6, 2010 | 12:17 AM
Bigredmariner's Avatar
I can't help you with your problem but wanted to say your truck sounds damn good. I was in the white CC Silverado that pulled up there this morning, sorry I didn't get out and say hey but as you know it was damn cold. Man your truck looks great and sounds healthy, hope you get the bugs worked out soon.
Old Dec 6, 2010 | 12:43 AM
charcold-bowtie's Avatar
Probably just a compounded problem in the set up, either wastegate flow or placement etc. I would just opt for a diff spring
Old Dec 6, 2010 | 12:22 PM
SRTKLLR's Avatar
Since a 14lb spring is giving you 16psi try a 12lb spring in its place. Or use the 10lb spring you already have with a boost controller to dial in exactly how much boost you want.
Old Dec 6, 2010 | 03:02 PM
chpspecial's Avatar
where are you getting the wastegate boost refrence line from. getting the reference from the manifold helps out vs. getting from the turbo outlet
Old Dec 6, 2010 | 04:48 PM
05stepside's Avatar
BigRed thanks for the compliment and you have a very nice truck. I hope your tune time went better than mine! HA HA
I'm highly thinking of installing my other spring and getting a controller.
SRTKLLR I was letting off the gas when it was hitting 16psi so I'm not sure where it would have stopped. Although 16 psi felt awesome, not being dialed in at 10*
chpspecial I'm getting it from the turbo outlet.
Old Dec 10, 2010 | 05:33 PM
02'Z71ONDUBZ''s Avatar
put the smaller spring in and buy an manual boost controller. that will fix all your problems, you can set the boost exactly where you want it.
