wastegate size?
Old Oct 3, 2012 | 01:51 PM
HIPSI's Avatar
I'd go with a jgs 50mm.. I've been down the road of having to small a wg and overboosting problems.
Old Oct 3, 2012 | 02:26 PM
nonnieselman's Avatar
Im running a Tial 38mm and its been good to me ever since i used it on the STS kit years ago and now on my KBracing kit.
Old Oct 3, 2012 | 07:35 PM
Beatdown Z's Avatar
Laid Back
I'm running a 38mm on my 5.3 and it can keep the boost as low as 7psi. At 14lbs a 38mm will do just fine.
Old Oct 4, 2012 | 07:31 AM
kush killer's Avatar
cool, thanks for replys guys, found a turbosmart 40mm for a pretty good price so i think ill jsut swoop that up.
Old Oct 4, 2012 | 07:32 AM
Originally Posted by lglowe
What 76mm turbo?
And are you dump waste gate to atmosphere and how big of an exhaust are you gonna run.
on3 perfomance..
Old Oct 4, 2012 | 08:45 AM
the 38mm Tial is keeping mine around 5psi right now.
Old Oct 4, 2012 | 08:55 AM
lglowe's Avatar
But not when you open the exhaust Nonnie. You could use a bigger gate and so could i. I'm using the jgs 40? And the lowest boost I can make is 10 psi on a 6 psi spring. Has a lot to do with backpressure in the cross over and how well the exhaust flows post turbine.
dsbodley
Nov 14, 2015 09:46 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
old motorhead
Sep 29, 2015 08:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
