wastegate setup
Old May 14, 2014 | 11:29 PM
slow67's Avatar
Gingervitis Addict
Originally Posted by timmay208
Electronic BC are only ones that should be using top port
Not true. You can get a low pressure, pressure regulator and plumb it to the top of the gate.
Something like this:
Basically adds an air spring in addition to the spring in the gate.
Old May 15, 2014 | 08:18 AM
TURBHOE's Avatar
That's the type I was referring to.
Old Jun 25, 2014 | 03:40 PM
tim wellington's Avatar
Default top port
had mine wrong should been to top port . line off my turbo blows air not sucks .so having it on bottom really blows air in to diaphram opening gate .putting it on top helps spring hold gate close .so i can run more boost.
Old Jun 25, 2014 | 03:46 PM
timmay208's Avatar
you can run manual controller like that to the side of the gate to, you pretty much restrict the air instead of adding it if you are on side port
done that on several cars
Old Jun 25, 2014 | 04:12 PM
Default gate
ok then restricting air would make the spring control gate right ,so I am running a 5lb spring when had mine at bottom port opening valve turning to the + side would let air push gate open making less boost when close valve restricting air spring took over
Old Jun 25, 2014 | 04:16 PM
timmay208's Avatar
If you have a manual boost controller going to side port of WG and you tighten it (clockwise) it will block pressure going to the WG therefor adding boost
Ive only ever done electronic if im using the top port and having it controlled by computer in which case you use both side and top ports and its controlled by a electronic solenoid
simman22
Jan 21, 2017 10:27 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
GMCtrk
Oct 20, 2015 06:17 AM
chopperloco
Sep 28, 2015 08:40 AM
Tuckin15s
Sep 23, 2015 09:35 PM
