Wastegate and manual boost controller questions.
Old Aug 21, 2012 | 06:12 PM
  #31
Johnmaster's Avatar
MASS seller approved
Synapse here, 2 springs that cover almost any conceivable combo and 3 different ports you can use to adjust boost without even using a controller. 2 different seat sizes and No diaphragms!
Old Aug 21, 2012 | 07:37 PM
  #32
scooter k's Avatar
Just talked to JGS and they said to put the standard spring in there and run a hose from the top port to the compressor housing. Then run another hose from the compressor housing to the end of the mbc and the perendicular fitting out of the mbc to the lower gate port. I have nothing to the compressor housing port wise. I have a vacuum block that's fed off the manifold. He said that won't work as the wastegate should only see boost and no vacuum.
Any of you agree with that? I so I'll have to drill a hole in the compressor housing.
Old Aug 21, 2012 | 07:46 PM
  #33
black04's Avatar
Nah it shouldnt matter if it sees vac. Tial told me the same thing but tons of people run it of the intake manifold.
Old Aug 21, 2012 | 08:01 PM
  #34
scooter k's Avatar
Ok Thanks! Won't be such a big deal then!
Old Aug 21, 2012 | 08:06 PM
  #35
scooter k's Avatar
With the standard spring and mbc will I be able to get it to 21??
Old Aug 21, 2012 | 08:35 PM
  #36
Ferocity02's Avatar
See my thread here, a couple diagrams. It's for an EBC but the idea is the same.
Turbosmart also says to use a pressure only source. I will be tapping into the compressor housing on mine.
Old Aug 21, 2012 | 08:38 PM
  #37
kbracing96's Avatar
Originally Posted by BlacKSS2oo2
First of all JGS wastegates are horrible. I am on my 2 JGS gate. The first gate melted all the internals and I lost all boost and a huge vacuum leak. Please buy a Tial gate and request whatever spring you would like. It is worth the 245 dollars for the Tial. You can buy the flange style or band style.
I've sold probably 50 JGS WG or more... Only ever had issues with 2 maybe 3 of them. Even JGS said they had never seen anything like what happened to yours... I have a JGS 50mm on my truck and never had any issue with it
Old Aug 22, 2012 | 03:27 AM
  #38
FI FREAK's Avatar
formerly BlacKSS2oo2 (9-20-2012)
Well the only problem was that the 4 bolts that hold the hat on backed out and destroyed the diaphragm. I think that I am just unlucky
Old Aug 23, 2012 | 08:51 PM
  #39
scooter k's Avatar
Where on the compressor housing should I be drilling and tapping? How big? Like a 90* 1/4" barbed fitting, 1/8" npt?
Old Aug 23, 2012 | 09:17 PM
  #40
Byrdman11's Avatar
1/8 pipe at the output.
