Wastegate leaking around the valve guide ?s.
Old Jul 18, 2009 | 10:43 AM
Stampede4ever's Avatar
Default Wastegate leaking around the valve guide ?s.
I was testing my new wastegate with an air compressor, and I'm getting some leakage at the valve guide. Is this normal? It's not bad, but I can here it leaking, and I can feel it when I cap the ends with my hands.
Stampede.
Old Jul 19, 2009 | 02:35 PM
the slo1's Avatar
What brand is it? Where did you put the air pressure? how much pressure did you put in it?
Old Jul 19, 2009 | 02:52 PM
charcold-bowtie's Avatar
shouldnt matter i wouldnt think. the only time air is moving right there is when the WG is open anyway.
Old Jul 19, 2009 | 03:09 PM
I only had about 10-15 psi on the lower fitting. I'm going to take the wastegate apart, and check how much clearance there is. So my next quesiton is how much clearance should there be?
Stampede.
Old Jul 20, 2009 | 10:08 PM
Rick_Vor's Avatar
Stampede.
I'd call one of the Wastegate Manufactures before you take it apart. As long as the valve is seating at rest, it shouldn't matter if a little presure gets past the valve guide. Besides, I would imagine as long as you have a free flowing exhaust, you wouldn't see too many psi when the gate is open.
I'm sure a quick call the a tech line can clear this up.
Rick
Old Jul 21, 2009 | 05:00 AM
I checked the clearance, it's only 0.005".
Stampede.
Texas5.3_1251
Mar 5, 2016 08:10 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
chopperloco
Sep 28, 2015 08:40 AM
726.0chevelle
Sep 12, 2015 09:24 AM
cousblake11
Sep 9, 2015 06:52 PM
