Walbro 255 swap
Old Dec 12, 2011 | 12:46 AM
dmelvin's Avatar
Default Walbro 255 swap
Guys, I know there was an awesome thread on here about swapping an in tank walbro pump in place of the stock one, but I can't find it anywhere. Had basically a step by step how-to, I can't remember any of the keywords to search for that I haven't already searched.
Truck is a GMT800, Return style.
Really appreciate if one of you guys have it saved or know what to search for to find it.
On a related note, can you run a single 255 pump with the stock fuel pump wiring or do you need to upgrade to 12 ga.?
Thanks guys!
Old Dec 12, 2011 | 07:05 AM
slowec's Avatar
call Racetronics!
Old Dec 12, 2011 | 08:38 AM
carbongmc's Avatar
^^ I agree, call them. They make a harness that's plug and play. If I remember right, it's only like 60 bucks.
Old Dec 12, 2011 | 10:55 AM
dmelvin's Avatar
I'll take that as it's a good idea to upgrade wiring. I'll give them a call and see what they recommend.
Anyone know what thread I'm talking about with the step by step install?
I could probably get away with a 190lph pump, I'm just running out of pump around 5300RPM. At this time I don't plan on adding boost... but I've always been known to change my mind before
Old Dec 12, 2011 | 11:11 AM
BlackGMC's Avatar
Resident Retard
I am running the stock wiring. I got my 255 from magnacharger. They make a nice kit. Just download the instructions for installing a supercharger for you year and they have an entire section on installing the pump
Old Dec 12, 2011 | 11:28 AM
dmelvin's Avatar
For my year, they apparently use an inline pump, I think I can get by the the instructions with the 03-06 though.
Old Dec 12, 2011 | 01:10 PM
02'Z71ONDUBZ''s Avatar
its really not hard once you get in there, just takes a little sanding and grinding. be aware that their are many different styles of 255's as far as the pickup goes, the pump that comes in the f-body kit has an offset that allows you to secure the pump well to the bucket and still use the factory pickup location after some sanding and grinding. also buy 1' of gates submersible efi hose to replace your stocker. should be around $20 and comes individually pre-packaged. your parts store will probably not have it in stock.
Old Dec 12, 2011 | 03:14 PM
dmelvin's Avatar
I believe I've read that F20000169 is the part number I need to get for the pump. Anyone know if this looks right off of the top of their head?
Old Dec 12, 2011 | 03:47 PM
yes that is the pump with the right offset.
Old Dec 12, 2011 | 04:22 PM
jiar577's Avatar
Subscribed
