Walbro 255 not enough, What next?
Old Mar 25, 2008 | 08:28 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Something is off.
you should be making more than 4 llbs, your track time of 12.3 is proof you are making more power than 4lbs would warrant.
The 43lb injectors are good to about 450hp without meth.
Old Mar 25, 2008 | 11:52 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
TWO 340s...
Old Mar 25, 2008 | 03:52 PM
quicksilverado's Avatar
Do you know what the fuel pressure is? You could have a clogged fuel filter and you are not getting the correct fuel pressure to the fuel rails.
Old Mar 25, 2008 | 04:03 PM
ZZebes's Avatar
Originally Posted by TurboBerserker
TWO 340s...
Dual intank setup with a hobbs switch
Old Mar 25, 2008 | 05:45 PM
8ALTNG's Avatar
two Bosch 420L pumps and some 96lbrs
Old Mar 25, 2008 | 05:59 PM
ZZebes's Avatar
That works to haha
Old Mar 25, 2008 | 06:01 PM
rgvsierra's Avatar
for real?
Old Mar 25, 2008 | 06:59 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Check the fuel pressure as well, be sure it's more than 50psi at wot and top of gear. Since yours is an 01, you probably have just one inline pump and your stock intank pump. Maybe your stock intank pump can't keep up and is a little weak. With the times in your sig and the boost level, the addition of an intank should be enough. I know it'll support around 580hp to the wheels.
If the a/f ratio is still lean and the fuel pressure is good, check the tune.
good luck,
allen
Old Mar 25, 2008 | 07:05 PM
8ALTNG's Avatar
Originally Posted by rgvsierra
for real?
Y??? Not enough???
Old Mar 25, 2008 | 07:30 PM
stock48's Avatar
9 Second Truck Club
With one intank 255 I made 581 uncorrected to the wheels on a stingy AWD dyno. I was running a 30%E85 mix, with no meth. One 255 set up right in the tank, with meth should be good for 600+RWHP on an efficient setup, and trap well over 120MPH in a 2wd truck. Sounds like you are making decent power for only 4psi. What size is the engine?
