Is walbro 255 enough??
Old Feb 5, 2008 | 07:00 PM
HorsePower Hunter's Avatar
Default Is walbro 255 enough??
I'm in the middle of a front mount turbo fab. The shop doing the job wants to put a single walbro 255 for a grand national good to about 700 hp. Is a single enough or to I need two? I plan to run around 10 lbs. of boost. Truck has 62 lbs injectors I believe. Also, does anyone know if there is a fuel regulator that fits on a stock LQ4 fuel rail.
Old Feb 5, 2008 | 07:04 PM
dirt track racer 81's Avatar
having two wont hurt..and i dont think there is an aftermarket regulator to fit the stock lines..just get an ls6 intake and do some aftermarket rails and put you an aftermarket regulator in
Old Feb 5, 2008 | 07:23 PM
kbracing96's Avatar
A single should be enough to max out 62lbs/hr. Stock fuel lines and reg have been proven to flow enough for well over 800rwhp with twin intank pumps.
Old Feb 5, 2008 | 07:33 PM
So, I should be able to get by with one pump for around a 500ish hp range and the stock reg will work?
Old Feb 5, 2008 | 08:54 PM
kbracing96's Avatar
I'm make 505rwhp with 1 255 intank pump and maxing out 43lbs/hr injector in my truck with a stock reg.
Old Feb 5, 2008 | 09:05 PM
Great!! That's what I wanted to hear Thanks
Chavette
Oct 28, 2015 07:33 PM
Vortec350ss
Oct 10, 2015 09:11 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
slocaddy
Sep 25, 2015 12:42 PM
97_ek
Sep 23, 2015 09:16 PM
