W2A set up pics
Old Oct 5, 2013 | 09:35 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by TURBHOE
that was my original thought. do you have any pics? how big is it?
also i was thinking about getting a 4.8L radiator and fans and mounting them where the spare tire goes. should i mount it flat and parrellel to the body or angle it just a tad? wondering if there is enough airflow that mounting it at a slight angle would be helpfull or it would just be better off mounting it flat. if i did mount it flat would it catch air underneath? seems like mounting it at a slight angle would at least keep wind from catching it and pulling down on it as speed.
I have some pics floating around. Took a radiator and mounted it just behind the tranny flat under the drive shaft. For use as a heat exchanger.
Add 2 good fans and that will work fine for an HX.
Route through the heater core and even better.
Old Oct 5, 2013 | 09:38 PM
TURBHOE's Avatar
so would stock radiator be too much cooling?
Old Oct 5, 2013 | 09:42 PM
TrickTurbo's Avatar
Truck Sponsor
No, if you have the room;
Put the largest HX that can fit.
The larger the HX the closer to ambient the water will be on the discharge temp.
Old Oct 5, 2013 | 09:45 PM
TURBHOE's Avatar
if i could get the quick disconnects for both sides i would do that for sure. just need the quick disconnect to attach the hoses together from off the fire wall.
Old Oct 5, 2013 | 09:56 PM
TURBHOE's Avatar
i wonder how much water the stock rad holds. maybe a gallon?
Old Oct 5, 2013 | 10:00 PM
TrickTurbo's Avatar
Truck Sponsor
No quick connects kill flow.
Just loop the two heater hoses in the summer time.
But the heater core thing is more for all out cooling.
I think with a large enough HX no need for heater.
Old Oct 5, 2013 | 10:07 PM
TURBHOE's Avatar
the heater core and hoses already have a quick disconnect though.
Old Oct 6, 2013 | 03:24 AM
TURBHOE's Avatar
now i need to figure out how to do the routing of th hoses and placement of the pump and resevoir. so the heat exchanger will be in the back behind the axle. then either put the res up by the one for the engine. or mount the batt back there too and mount the res right there. if i did that i could mount the pump right below it and then to the intercooler and back to the H/E. question is, can the pump push the water through the IC then all the way back through the HE back to the front and up to the res?
Old Oct 6, 2013 | 07:40 AM
TrickTurbo's Avatar
Truck Sponsor
Depends on the pump.
You want the water to gravity feed to the pump.
As straight as possible.
I have had customers that use 2 cheap eBay pumps before.
You want the water to flow as fast as possible for best results.
Old Oct 6, 2013 | 05:15 PM
TURBHOE's Avatar
i understand it needs gravity feed which to mean just means make the res higher than the pump. but can the pump push "up hill" so to speak?
