VS8375 on 4.8?
Old Aug 11, 2019 | 12:13 AM
DeucesALLin's Avatar
Default VS8375 on 4.8?
Wheatley spec'd the turbo. Rick at Trick liked it the first time we talked, then when my kit got done he thought it might be big. I Tried searching and have found nothing- which is making me nervous....
Gen IV truck motor, stock intake/cam/799 heads; 918 springs. Decaps flowing 90+.,
e85+meth, non-intercooled Trick Turbo Stage 5 kit, VS 8375 in cast.
TH400,3800 converter,3.23 gears.
Turbo specs:
75/105 Compressor
83x75 Turbine
1.10AR Housing, divided
Will this thing light anywhere near my stall speed?
Will a new cam be more beneficial than a quick spool valve?
Can you point me to any similar builds?
Thanks.
-Jake
Old Aug 11, 2019 | 02:03 PM
03sierraslt's Avatar
What’s your stall speed? When did Charlie start spec’ing turbos? Did he maybe suggest it? What’s your current cam? How much HP do you want? What’s your goal. We can’t read minds
vortec350ss is using that same turbo on his 4.8 I believe. Cast 75/83
Old Aug 12, 2019 | 12:40 PM
hunterbohanan23's Avatar
I mean, I would personally throw a turbo cam in it to help regardless.
Old Aug 13, 2019 | 11:06 AM
Vortec350ss's Avatar
You'll have no issue lighting that turbo on that converter. I can give you feedback soon... mine will be running shortly. I have the same turbo with a T6 flange on a 4.8.
LostInTheSauce
Jun 21, 2015 03:04 PM
kody1k
Jan 7, 2012 02:15 PM
boosted 4.8
Dec 18, 2011 10:27 PM
.2fast4u.
Jun 26, 2006 06:53 PM
