Very Bad Issues/Turbo
Old Mar 28, 2010 | 05:55 AM
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by bansheerider44
ya, return pump probably failed for a bit, even if it came back on, it probably messed up the seals and the oil will continue to pass them untill rebuilt... same thing happened to me on my sts kit..... my suggestion, is go front mount... but i know thats not easy, so I would say get a new pump and have turbo checked/ rebuilt. hope this helps....
x2
Happened to me also.
Also have a good oil return line made. That one that comes with the kit is cheap and could leak. i had an underhood fire cuz my oil return line leaked.
So i had a local hydraulic hose place make me a good return line.
Also carry a spare relay for your oil pump. never know when you'll need it.
Old Mar 28, 2010 | 07:17 AM
bud8fan's Avatar
Originally Posted by TIM Z
x2
me too...had a relay go bad and almost pumped all the oil outta my motor...turbo was FUBAR after that.
Old Mar 28, 2010 | 09:43 AM
06pcklm7's Avatar
Ok i understand. We did have the oil pump backwards at first. But never cranked the truck just turned it over about three good times, becuz we had a fuel pump issue that was in the tank and couldn't figure out why the truck wouldn't crank, so we fixed that and the oil pump same time before we ever got the truck to fire. Then after it did crank oil runing from bothsides. So i guess i need a cheap turbo to get my daily driver back on the road till i can find someone to rebuild this one . If ya'll got any ideas would be greatly appreciated. It's setup for t4 flange with 3in v band.
Old Mar 28, 2010 | 10:00 AM
06pcklm7's Avatar
yes this sounds like my problem i will be going front mount as soon as i save up a little more cash but thanks for the help.
Old Mar 28, 2010 | 10:50 AM
kbracing96's Avatar
I can get you a brand new Master Power T70 with a 1 year warranty for $625 shipped.
Old Mar 28, 2010 | 10:56 AM
1BADAZZSS's Avatar
What size turbo came with the kit 60,67? Might be able to find someone local that can rebuild it. Prob just need new seals. But I also heard ppl having good luck with ebay turbo's too. I had my starter stick on me one time while the ingition was off. Other words the engine was turning over and there was no power going to the pump. Oil was coming out both sides of my turbo and the exahust was still hot and looked like a smoke show. Ended up having to disconnect power from the battery. I just ended up pulling the cold side off and cleaned all the oil out of it, put everything back on and hasnt pushed any oil since. Might be able to try that.
Old Mar 28, 2010 | 11:47 AM
06pcklm7's Avatar
this was a older kit it came with a 60 but he said it lasted about 60,000mi, so he got the 67 next but put the 60 cold side on the 67 because of boost lag??? Does this make sense? So i am still trying to figure out my turbo size and stuff my self... Next I haven't changed anything with my pcv valve its a 2006 rcsb with a lm7 5.3 flex fuel truck.
Old Mar 28, 2010 | 02:31 PM
BlownChevy's Avatar
blownerator
25 Year Member
x2
Me 4 and it only cost one motor
Old Mar 29, 2010 | 02:43 PM
turbosilvi's Avatar
i had my relay go bad, that small rectangular gold thingy that gets REALLY HOT. it went bad, i called sts and talked to chris (awesome guy) and he walked me through what it was and he said to get rid of the gold rectangular things and just connect the wires... that keeps the pump on high all the time. he said that with further testing, they found that keeping the pump on high is better. another problem that it might be in the sylenoid that activates the pump may have bone bad. u just need to call sts ( 1 866 938 8726) and ask for chris, hes a great tech who definately knows what hes talking about! good luck
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
