Very Bad Issues/Turbo
Old Mar 27, 2010 | 11:40 PM
06pcklm7's Avatar
Default Very Bad Issues/Turbo
So i bought a sts kit used from a guy on the site. The kit was installed pretty easy. Sts is very helpful over the phone. But I can't figure out why I have oil coming out my tailpipe and it is in the cold side too.?? I have called a number of people and they kinda are giveing me the run around?? I need my truck to run like asap. I have checked over everything like 6 times.... do not understand help plz...
Old Mar 27, 2010 | 11:42 PM
00Silv4.8's Avatar
out the cold side? so its coming out of the intake? wha?
Old Mar 27, 2010 | 11:43 PM
GMCtrk's Avatar
Turbo might be leaking
Old Mar 27, 2010 | 11:44 PM
06pcklm7's Avatar
Default turbo
Yes both sides of the turbo have oil coming out
Old Mar 27, 2010 | 11:46 PM
06pcklm7's Avatar
How do i fix that? thanks for the replys guys.
Old Mar 27, 2010 | 11:50 PM
kbracing96's Avatar
Your return pump is not working right. Check and make sure it's not running backwards and that it is pumping the oil back to the motor.
Old Mar 27, 2010 | 11:56 PM
06pcklm7's Avatar
Ok yes that is what i thought at first was the pump too, so i cut the hose and made sure it is pumping back into the motor (oil cap,) put it all back together right then drove it down the road it still doing the same thing??
Old Mar 28, 2010 | 12:22 AM
BlownChevy's Avatar
blownerator
25 Year Member
More than likely there is residual oil in the exhaust that might need to burn off. Have you verified the return pump is working?
Old Mar 28, 2010 | 03:54 AM
Spoolin's Avatar
GFYS and STFU
Old Mar 28, 2010 | 05:28 AM
bansheerider44's Avatar
ya, return pump probably failed for a bit, even if it came back on, it probably messed up the seals and the oil will continue to pass them untill rebuilt... same thing happened to me on my sts kit..... my suggestion, is go front mount... but i know thats not easy, so I would say get a new pump and have turbo checked/ rebuilt. hope this helps....
