Vacuum source question
Old Jun 22, 2011 | 10:29 PM
otniel's Avatar
Default Vacuum source question
For those of you with a sts kit....where do you take your vacuum source for the boost controller?......from the intake manifold? Or the turbo itself?
I'm trying to figure out why I can't raise my boost past 10#.
Old Jun 23, 2011 | 05:09 AM
droppedchev's Avatar
I would take it from the intake the intake has a better source for seeing the psi that u want
Old Jun 23, 2011 | 10:00 AM
Swerve7rpm2000's Avatar
I just researched the same thing check this link out.... http://www.jgstools.com/turbo/tk188in1.jpg
Old Jun 23, 2011 | 12:47 PM
N20GMC's Avatar
There is a vacuum port on the passenger side of the intake. Break the little tab off and stick your line on there and zip tie it.
I just saw this wasn't a GM. So I have no idea where it is on a hemi.
Old Jun 23, 2011 | 07:26 PM
kazfan30's Avatar
You will see more boost from the manifold source when running on waste gate spring only.... when using a boost controller run off the Turbo compressor for boost source. Plus every wastegate company will tell you not to let wastegate see vacuum... it prematurely deteriorates the diaphragm inside. And boost will also come in sooner when off compressor vs manifold.
Old Jun 24, 2011 | 07:54 PM
cwalker2006's Avatar
In that case would you want to hook uo the wg to the turbo? And where can I picj up a good boost controller from. is the wg still used if I get a boost controller
Old Jun 24, 2011 | 09:08 PM
charcold-bowtie's Avatar
I've never hooked anything to a turbo. And yes, you obvsly keep your wg with a controller
Old Jun 24, 2011 | 10:15 PM
02'Z71ONDUBZ''s Avatar
Is your boost controller is inline the vacuum source to the wastegate? What spring is in your gate and what turbo
lucas287
31
Jan 12, 2021 06:18 AM
blownss27
Aug 14, 2020 08:27 AM
custm2500
Sep 8, 2015 05:53 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
