Vacuum canister for boost references
Old Oct 6, 2014 | 12:05 PM
TURBHOE's Avatar
Default Vacuum canister for boost references
Anybody run a can off of the manifold to have a localized spot for things that need boost referenced? I'm going to a l92 intake and it has less ports that's my old one but it has one big hole on top that looks like it would be a good place to tap and run a 1/2" line off of into a canister. My 2bar map sensor doesn't look like it will even work, it's too tall for the hold down strap. I just want a clean install with out an *** load of T fittings everywhere.
Old Oct 6, 2014 | 12:33 PM
camarokid6771's Avatar
hope this link works McMaster-Carr
Old Oct 6, 2014 | 12:34 PM
Atomic's Avatar
I have a gauge for that
Not a good idea using a big canister IMO, too much surface area. A vacuum manifold off ebay would be a much better idea.
You can make your 2bar sensor work with some steady dremel work. Worked for me anyway.
Old Oct 6, 2014 | 07:35 PM
TURBHOE's Avatar
The can I have is pretty small.
Did you take off material from the top of the map or from the bottom of the hold down strap?
Old Oct 6, 2014 | 07:43 PM
Atomic's Avatar
The top of the map. Peeled off the sticker, ground slowly, put sticker back on.
Old Oct 7, 2014 | 08:06 AM
TURBHOE's Avatar
That was my first thought for that thing but I wasn't sure how far I could go.
Old Oct 7, 2014 | 08:39 AM
Atomic's Avatar
I think I might still have my old one if you would rather buy it instead of cutting yours up...
elir_mn
Sep 19, 2015 11:43 AM
2500ZL1
Sep 12, 2015 03:50 PM
creekrat
Sep 10, 2015 12:59 AM
cousblake11
Sep 9, 2015 06:52 PM
custm2500
Sep 8, 2015 05:53 PM
