Vacuum canister for boost references
Anybody run a can off of the manifold to have a localized spot for things that need boost referenced? I'm going to a l92 intake and it has less ports that's my old one but it has one big hole on top that looks like it would be a good place to tap and run a 1/2" line off of into a canister. My 2bar map sensor doesn't look like it will even work, it's too tall for the hold down strap. I just want a clean install with out an *** load of T fittings everywhere.
Not a good idea using a big canister IMO, too much surface area. A vacuum manifold off ebay would be a much better idea.
You can make your 2bar sensor work with some steady dremel work. Worked for me anyway.
elir_mn
Sep 19, 2015 11:43 AM
creekrat
Sep 10, 2015 12:59 AM
