Upgraded Holley fuel rails
Old Apr 13, 2015 | 06:50 PM
Wareagle23's Avatar
Default Upgraded Holley fuel rails
Ok so here's what's going on. Upgraded injectors fic1000, and upgraded to Holley return less fuel rails. They leak when you turn the key to prime them. Put the spacers on the rails to fit the taller injectors and used vasoline per fuel injector connections instructions. New o rings and just about everything else you could think of. Here's the crazy part, if you put the stock rail on, no leaking at all. What gives? It on a 2011 GMC Sierra 4.8 with a 76mm turbo. Holley part number 532-209. Any of you guys run into this?
Old Apr 13, 2015 | 06:52 PM
GMCtrk's Avatar
Probably needs different injector o-rings.
Old Apr 13, 2015 | 10:38 PM
Wareagle23's Avatar
Tried two different sets
OHsixLS3
Dec 27, 2016 09:30 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
GMCtrk
Jul 17, 2015 06:39 PM
