Under Truck (rear mount) Q's
Old Jul 12, 2012 | 08:11 PM
  #31
quicksilverado's Avatar
Originally Posted by shaw_426hemi
Anyone have any experience with the comp oil-less turbos? I need to do some research into them, but the idea sounds sweet and expensive. I feel like a coolant line is more reliable than a oil line. My biggest concern is the oil return pump failure which i guess if it had a guage in line to monitor return pressure it wouldnt be too bad.
There are a few guys on tech running them with good results.
Old Jul 13, 2012 | 10:06 AM
  #32
shaw_426hemi's Avatar
I looked at those, got me real interested. So i have some questions that you guys can most definatly provide insight into.
1. How much boost can I run reliably on this motor and daily drive it and drive it on road trips without comprimising logevity of life or melting it down. Keep in mind i plan Turbo spec'd cam and prolly springs, but stock 6l80e, stock heads, valves, intake, gaskets, bottom end, don't anticipate a stud kit or a meth kit.
2. If i end up with a traditional turbo as opposed to the comp oil less turbo, has anyone seen a self contained oil system with a resevoir, filter, scavenger and maybe a oil cooler? This is just a thought, also wonder about proper oil temp with this set up, would that be a concern?
3. I have a catted Y on my ARH Lts and initially thought mid mount would come right off of ARH collector flange into a custom short pipe with waste gate and then turbo flange, but I realized the catted Y could reduce velocity so should I swap to a ARH non-catted Y or have my mandrel exhaust shop bend me a smaller (maybe 2.5" cat-less Y) with room for the wastegate and then the corresponding turbo flange?
Bouncing around ideas, I plan to build this kit and assemble the parts myself as many do to keep cost down yet keep streetability. Im trying to get the Turbo setup and specs dialed down then tackle the cold side second and then fuel issue last. Ohh and tuning i was thinking Justin at BB could help me with that since hes tune is in the truck now. Keep the thoughts coming from those with experience!
Old Jul 13, 2012 | 10:22 AM
  #33
Electric Oil Feed and Scavenge Pumps
Some well recommended pumps for anyone who is interested.
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
