twin turbo 4.8 lifter tick - upgrade heads?
Old Nov 11, 2015 | 12:05 PM
TrendSetter's Avatar
Default twin turbo 4.8 lifter tick - upgrade heads?
Hey i have a junkyard 4.8 with twins, its been together about 1.5-2 years, taking some good abuse. 100% street driving
its stock bottom end, tu0 cam, dual springs, hard pushrods, ebay head studs, mild port work on heads. everything else stock.
the lifters have started making noise, so i think its earned a new set.
as long as the heads are off, is it worth getting a set of 243s for it? i can do all my own labor, i have all the parts to use a bare set of castings, i would just need to pay for castings and flat milling. i would throw some mild port work at them and all the parts off the 4.8 heads(i have a correct set of intake valves already).
thanks
Old Nov 11, 2015 | 01:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It certainly wouldn't hurt to add those heads.
IMO, I would loose the Ebay head studs and get a quality set of lifters.
The cheap studs have been tested and found to be weaker than a factory TTY bolts.
Old Nov 13, 2015 | 07:20 AM
nobody has swapped from 4.8 heads to 243s on a 4.8?
Old Nov 13, 2015 | 12:08 PM
03regcab sierra's Avatar
I did it on my twin turbo 4.8. I'd say it's worth the money to do the swap
AdaMax
May 16, 2016 11:35 PM
1989k1500
Nov 2, 2015 05:16 AM
Slammed silverado
Sep 28, 2015 06:14 PM
maxspeed05V
Sep 23, 2015 10:48 AM
jfuegner
Sep 22, 2015 12:30 PM
