twin stock pumps?
Old Jan 18, 2012 | 09:25 PM
ivan_key's Avatar
Default twin stock pumps?
Ok I heard of some guys running twin stock pumps in their NNBS trucks, does anyone have any information about this and how I can do this? I have searched with no luck. Thanks
Old Jan 18, 2012 | 09:42 PM
smokeshow's Avatar
Mod with training wheels
I ran twin stockers. Original pump ran like normal, second pump was on a hobbs switch that came on around 5psi. Had to hack up the bucket to make it work.
Old Jan 18, 2012 | 09:47 PM
ivan_key's Avatar
I probably would run into the same problem with my fcpm wouldn't i
smokeshow's Avatar
What problem?
Old Jan 18, 2012 | 10:08 PM
ivan_key's Avatar
Well like the problem when running a walbro it will burn it up
Old Jan 18, 2012 | 10:10 PM
smokeshow's Avatar
A walbro isn't a stock pump lol.. But if you tune out the variable fuel pressure settings, a walbro should do fine.
Old Jan 18, 2012 | 10:25 PM
ivan_key's Avatar
Lol I know that, but I'm thinking that adding an extra stock pump would get messed with from the fpcm, anyways you say tune it out?, if I add a couple walbros I can just pull the fuse and tune it out?
Old Jan 18, 2012 | 10:44 PM
smokeshow's Avatar
You don't add the second pump to the stock wiring, FPCMs cannot handle the extra current draw. It needs to be controlled independently. You don't tune out the FPCM, just the variable pressure settings. Set it to 58psi across the board and be done with it. Fuse needs to stay in to monitor fuel pressure.
Old Jan 18, 2012 | 10:52 PM
ivan_key's Avatar
Oh I get it now lol, didn't think about that stuff, so what do you think should I waste my time with twin stock pumps or just throw a walbro in there and get it tuned? I'm keeping it at least 9psi or under for awhile
Old Jan 18, 2012 | 10:57 PM
smokeshow's Avatar
A single walbro would handle that...consider about how many times you want to do the fuel system, though.
