Twin intank build
Old Nov 19, 2010 | 05:52 PM
  #31
shawnss's Avatar
wow nice and clean. should pump some fuel. ill be doin this down the road at some point.
Old Nov 19, 2010 | 07:51 PM
  #32
GetBlown01's Avatar
may be a dum question, but did you just splice in to original power and neg. coming off of the pumps? i see you have all 4 wires coming off of each pump, just wondering how you did it.
Old Nov 19, 2010 | 08:08 PM
  #33
2toneblown's Avatar
Yes. Took the original clip apart and took the wire out and put 2 wires from the 4 wire bulk head into the original Walbro clip since I am going to run a BAP on each pump
Old Nov 19, 2010 | 11:51 PM
  #34
Rick_Vor's Avatar
Originally Posted by 2toneblown
Lightning Force Performance
Thanks 2toneblown.
Gates submersible fuel line. Kinda expensive but it's what works.
You aint kidding. $20 a ft but a deal for the piece of mind it brings.
Rick
Old Nov 20, 2010 | 10:52 PM
  #35
GetBlown01's Avatar
thanks bro
Old Nov 21, 2010 | 01:37 AM
  #36
Atomic's Avatar
I have a gauge for that
How much of that gates hose did you end up using? More than a foot?
Old Nov 21, 2010 | 11:22 AM
  #37
2toneblown's Avatar
I got 2ft of it just to be on the safe side. I dont know if I could have gotten by with 1 or not. I built it with just a short Y and them realized it had to compress down quite a bit so had to redo it with that big loop in it, so I ended up using both feet.
Old Nov 23, 2010 | 03:22 PM
  #38
vortecyota's Avatar
You are the man! That is the cleanest twin install I've ever seen. Thank you for sharing it here!
How about the filter socks that usually go on the bottom of the pumps? Did you find a way to keep em and not have to butcher the bucket?
Old Nov 23, 2010 | 03:44 PM
  #39
2toneblown's Avatar
1 pump sits in the factory location, but it doesnt go flush with the bottom of the bucket so I cant cut it and make the sock fit. The second pump can go flush on the bottom and could receive a filter but dont want to run 1 with and 1 without so I will probably just run them without the sock filters.
Old Nov 24, 2010 | 06:47 AM
  #40
vortecyota's Avatar
Will that be ok?
