TVS2300 Dyno test
FormerVendor
TVS2300 Dyno test
I'm not sure if this got posted here earlier or not, but I find this TVS2300 Magnusson topped 434ci engine simply amazing. Built by Ken Dutweiler it made 450ft/lbs of torque WOT at 1000rpm, 855ft/lbs at 2500 and still carried enough beans to make 950hp at 6500. Peak torque of 930ft'lbs at 3600rpms. I was told the cam size is in the mid 230º's. The heads are CNC ported L92's with big valves in them.
950 HP Blown LSX DYNO
Richard
Richard
Sounds similar to the first Kenne Bell car we built. It had a 2.8 on it with a 402 LS2, small 230ish cam, AFR 225's and made about 800t lb at 2600 rpms on the dyno. hehehe. Gota love Posi blowers when they can handle the motor size.
Rick
Rick
That was bad ***. The TVS2300 is the same as on the ZR1? Right? Shows that there is plenty of potential for the Z also shows that Kenny can build sme bad azz shizz but we knew that allready.
