Tvs2300
Old Jan 20, 2009 | 10:30 PM
  #71
moregrip's Avatar
what a rush!
questions I have is will 8rib be enough? have you thought about going cog? 10rib maybe?
Old Jan 20, 2009 | 10:32 PM
  #72
NORCAL TBSS's Avatar
Restricted User
ill see how the 8 rib does. if im gettin 12 psi slipping now im sure with 8 rib ill be ableo to get 15 easy.
Old Jan 20, 2009 | 10:41 PM
  #73
zippy's Avatar
I think the 8 rib will be more than enough for a front drive unit. I'm interested in seeing just how fast you can go on the 6 rib.
Old Jan 20, 2009 | 10:48 PM
  #74
Restricted User
im upgrading the belt to the good year one and then seeing what happens.
Old Jan 20, 2009 | 11:16 PM
  #75
2004SSS's Avatar
what tensioner are you using? i think that is a big part of how much slip you will see. the stock tensioner is not something i would use. the magnacharger 8 rib one is a minumum on a setup like this.
Old Jan 20, 2009 | 11:18 PM
  #76
Restricted User
yes maggie 8 rib
Old Jan 21, 2009 | 09:59 AM
  #77
OnyxSilveradoSS's Avatar
Originally Posted by supersub
LMFAO! Bout time someone else asked that question. A little too much hype.
Who posted that pic of the big crank pulley??
you know with the guy grinding on it.
com'on Ray you know you want one
Old Jan 21, 2009 | 10:02 AM
  #78
Restricted User
why to much hype?? This is bad *** and iat temps are under 110 after 5 back to back runs at 11.5 psi boost and drop down so fast.
Magncharger did this right with the tvs line
Old Jan 21, 2009 | 10:12 AM
  #79
I believe the 'hype' was guys were putting things together last winter and wanted to run the 2300's and I dont think they were 'ready' or 'done' so guys had to go 122 to have their trucks running this past season, now (in Ray's case) is it worth the cost and changes to your set-up to run the 2300???
From my reading of the charts, graphs the awnser must be yes.
Old Jan 21, 2009 | 06:31 PM
  #80
zippy's Avatar
I think the biggest point with this blower is that it should to be faster at say 12psi than a 122 would be at 15 or 16psi. Even at normal boost levels it's going to be impressive without spinning it to the moon like previous models.
