Tvs1900 5.3, Stock cam shift points?
Old Feb 3, 2016 | 07:30 AM
embs2001's Avatar
Default Tvs1900 5.3, Stock cam shift points?
Im wondering if it is worth it to move the stock shift points from 5500 up to 5800-6000? Its a stock cam LM7 with 9psi boost, Longtubes, true dual exhaust, 90mm throttle body, Drop in K&N filter, 2800 stall, And 3.73 gears. RCSB 4x4. Not expecting more power from it, just quicker with less rpm droo.
Thanks, Let me know what you think!
Old Feb 3, 2016 | 07:44 AM
03sierraslt's Avatar
You could but be aware of valve float, stock springs are pretty weak. I would say closer to 5800
Old Feb 3, 2016 | 09:47 AM
2 SSlow's Avatar
Throw some LS9 valve springs in there for $57 and let'er eat.
Old Feb 3, 2016 | 11:02 AM
embs2001's Avatar
Thanks guys.
I have some yellow ls6 springs I got for free, just too lazy to put them in. I imagine the stock cam doesnt have much to offer past 5800 anyway?
Old Feb 3, 2016 | 01:27 PM
Vortec350ss's Avatar
Yea I wouldn't bother going past 5800. 5800 and 10psi would feel strong. As you push the boost higher your cam will start to fall off even earlier. I would definitely upgrade those springs...
The more boost you make the less your shift extensions will be of concern. It will pull hard in the mid range. Out of curiosity what pulley are you running to make 9PSI?
Old Feb 3, 2016 | 02:00 PM
embs2001's Avatar
This is a lsa blower with the stock 2.95 pulley. Its usually around 8psi in the lower rpms and climbs to 9 in upper. not sure why its like that but I suppose its because the blower is spinning slower than it did on a LSA stock?
Old Feb 3, 2016 | 03:55 PM
Yes the LSA has a larger crank pulley than you do. Thats still a fairly small pulley to only make 9PSI on your engine.
Old Feb 3, 2016 | 06:23 PM
embs2001's Avatar
4 or 5 other people on the forums with the same blower on a 5.3 said they had 8.5-9 lbs with the stock pulley. The guy who sold me the adapter plates and fuel rail said everyone is seeing the same 8-9 with the stock pulley.
What would you expect from a maggie 1900 with same lower and upper pulleys?
Old Feb 4, 2016 | 12:10 AM
I guess Id have expected north of 10 for sure. Between the stock cam and smaller cubes. I made 10 with the stock crank pulley and a 2.7 upper. But 6.0 vs 5.3 and cam vs no cam...
Old Feb 4, 2016 | 07:15 AM
embs2001's Avatar
Yea it is weird. Something must be diffrent between the maggie 1900 and LSA 1900.
