>>TVS 2300 Denali Conversion RCSB <<
Old Oct 18, 2017 | 06:51 PM
  #121
Tig's Avatar
Tig
That's great news.
Man, I cant believe the cats were that bad. I can just imagine what your engine is saying right. "thank you, I can breath again" hahaha
Old Oct 19, 2017 | 11:24 AM
  #122
smokinlmm's Avatar
Retune netted almost 60 rwhp. Pulley change in progress....
Old Oct 19, 2017 | 11:28 AM
  #123
smokinlmm's Avatar
Pulley down for what???
First run pics before Jay put his mojo on it...
Old Oct 19, 2017 | 07:36 PM
  #124
smokinlmm's Avatar
Got well north of 400!!! Torque was almost 500 if that tells the tale...
Old Oct 24, 2017 | 04:14 PM
  #125
M60gov20's Avatar
Looks great! I really need to get started on mine!
Old Oct 25, 2017 | 08:00 PM
  #126
smokinlmm's Avatar
Changed front and rear diff fluid, pulled covers and cleaned them all up. Reused gaskets, they looked perfect, put in fresh GM grape aide with proper additive package for G80 and buttoned them up. Changed my transfer case fluid, I was shocked it wasn't auto track fluid? Auto 4wheel drive t case and it called for aft? Also had my trans guy drop the pan clean everything up, change internal filters and put in the blue Amsoil ATF. Lubed her up real good and gave her a good clay bar followed by the coat of 303 UV protectant. Started to detail underhood, got a lot done just need to get a chance to clean the fire wall and touch up the front frame section where it's coating has worn away. Noticed that my starter wire is touching my y pipe and is melting, guess I'll fix that and heat wrap it next. Truck is a blast to drive and with the 6l80 it's easy on the ears bc it's silent in 6th gear cruising.
Old Oct 25, 2017 | 08:04 PM
  #127
smokinlmm's Avatar
Fox 2.5 coil overs for 3" lift are next along with fox 2.0 in rear. I ordered shocks that are too short the first time.
Old Oct 25, 2017 | 08:05 PM
  #128
smokinlmm's Avatar
Thank you! Get moving man, I love driving mine!
Old Nov 3, 2018 | 06:31 AM
  #129
smokinlmm's Avatar
Well, 20k miles of daily abuse and something let go. She is a ticking like a clock. Lol.
Goes to Mayhem on Monday for all the top end goodies, head work, overdrive balancer and bigger sticks...
Old Nov 3, 2018 | 12:05 PM
  #130
_zebra's Avatar
makes children cry
that's gonna flow a lot better.
what cam'd you get?
