TVS 1900 vs radix mp112
Old Nov 15, 2009 | 04:14 PM
firechicken76's Avatar
Default TVS 1900 vs radix mp112
which is better? advantages and dissadvantages of the tvs 1900. ive got a radix, and I saw a similar build with the tvs, same motor as I have, he made about 500rwhp, just wondering if I would be less, more, or about the same.
here is his car
http://www.hawksthirdgenparts.com/ke...nsformula.aspx
mine is an 88 gta, ls1, headers, no cats, slp exhaust, ill have the 2.9 pulley, innercooled, and a blower cam.
and I was thinking about upgrading to the 90mm throttle body J tube, would i gain much from this?
and as for cams, ive looked at a few, the lingenfelter, the ls6, would I gain much more by going with the lingenfelter over the ls6? GT2-3 is the lingenfelter cam.
Old Nov 15, 2009 | 04:20 PM
Mangled03gmc's Avatar
Baltimore Whore
The 1900 is a newer, more efficant unit.. so def the 1900
Old Nov 15, 2009 | 05:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
the M112 felt like it had all of it's ball in the low end of the power band, the TVS has it al the way to the top and as far as I've seen the top goes on forever. I made ~50hp better with the TVS with a larger pulley IIRC
Old Nov 16, 2009 | 05:12 PM
Breeze's Avatar
11 Second Truck Club
I'm 3 tenths faster in the 1/4 mile with the Tvs 1900 then I was with the Radix 112.
Old Nov 16, 2009 | 05:24 PM
trever1t's Avatar
that sounds about right
Old Nov 16, 2009 | 05:55 PM
old motorhead's Avatar
The 1900 is bigger (same size as mp122) and is capable of more boost before heating things up too much. Compared to a 112, it's just bigger and better all over. You can use a little more cam with the TVS. Anything bigger than a mild cam is kind of a waste with a 112. A big cam might sound good, but the numbers aren't there if you're already pullied down to a 2.9" drive pulley.
Old Nov 16, 2009 | 06:12 PM
norris_83's Avatar
the tvs is amazing for iats!!! I had a couple 112s on the dyno and iats get crazy hot soon as you push on it, the tvs actually decreased when i was getting on it!
Old Nov 16, 2009 | 06:24 PM
fastnblu's Avatar
I wondered what were the numbers both in terms of HP & ETs. So that's the results, huh? Nice.
So, Bill, power delivery of Radix (down low) vs TVS (all the way to top) is like comparin a TPI to a LS engine.
old motorhead, you said 1900 is bigger (same size as mp122) and is capable of more boost before heating things up too much (meanin more efficient). Compared to a 112, it's just bigger and better all over. You can use a little more cam with the TVS. Anything bigger than a mild cam is kind of a waste with a 112. A big cam might sound good, but the numbers aren't there if you're already pullied down to a 2.9" drive pulley.
As technology marches on, I should hope things improve. Only downside I see to TVS is price is a bit more than Radix.
The rest seems like a total winner.
I also like how that black finish on TVS integrates w/. rest of engine for factory look.
Old Nov 16, 2009 | 08:59 PM
terravast4's Avatar
the 112 may have some shortcomings but but still produces gobs of power if you do it right and there quite a few for sale for cheap. if you are on a budget pick up a used 112.
Old Nov 16, 2009 | 09:14 PM
trever1t's Avatar
there is nothing wrong with the MP112....It is a great blower. Got me near mid 11's and still had more in it.
