TVS 1900 3.2lb pulley (8-9psi but only reading 5psi?)
Not too sure why this happened... I've installed the tvs1900 finally, but am running into boost problems! I have a feeling it might be belt slip since I had to get custom idle pulley brackets made and installed...
Could the exhaust limit the boost? I'm running the stock exhaust so far, waiting for my system to come in (around a week or 2).
If anyone can help or offer any insights, please lemme know!
Thanks
Thanks
i bought the kit used, and it was missing a few pieces...can you explain what exactly to feel when there is belt slip??? I haven't felt much difference then what it was before the supercharger... feels like around a 50hp gain, not the 120hp gain advertised??
Post a pic so we can see what you've got. You shouldn't be seening belt slip at 8-9 lbs bad enough to drop you to 5psi unless its really loose
Depending on what kind of timing your running on the E38 you will see huge variations in hp. If its the 1st time tuning a FI with an E38 your probably running 0-(-15) degrees of timing at WOT.
I have a gauge for that
If your exhaust sucked you would actually see more boost, since boost is a measure of air pressure which is in turn a measure of resistance...
When I think you arent seeing the amount of boost you see I think of:
- belt slipping (most likely)
- blower maxed (not likely)
- valve float (not as likely)
