Turning up the boost
Old Oct 17, 2012 | 01:56 AM
patofdzb's Avatar
im guessing its a RCSB, due to weight, you will want longer gears, thats why i just went back down to 3.73s.. 4.11s with the turbo will eat through 1st and 2nd very quick, and it will only break tires loose, which is not what you would want. Just my opinion...
I would read a little more if i were you
Old Oct 17, 2012 | 03:01 AM
SLO TRUCK's Avatar
leave the 3.23's its a turbo truck. You want it to do better from a dig get a 2 step and let it eat.
Old Oct 17, 2012 | 06:34 AM
TRD_Tundra's Avatar
Reason I don't like 3.23's is because I basically only run in 2 gears. 1st=70 2nd=80
And it only runs good from a 35mph roll
Old Oct 17, 2012 | 08:34 AM
nonnieselman's Avatar
A converter will fix all that..
im running 3.42s and 32" mud tires with a stock 80E TC. yea off idle it takes half a second.. but when it gets to moving, its gone.
more boost will make those 3.23s feel alot better.
Old Oct 17, 2012 | 10:30 AM
TRD_Tundra's Avatar
I just got it turned up to 10#'s it peaks 11.
But with stock 3.23's on a G80 locker what would be a good roll to race and to how many #'s should I brake boost?
A 03 Lightning with 15-16#'s, Stage 2 cams, and FBO wants to race me.
Old Oct 20, 2013 | 08:36 PM
LS1TRUCKGUY's Avatar
i have the same setup as you except i have 70mm, 3.73s, and a circle d 3000 multidisk. im currently running 13psi. it runs its *** off from a dig or a roll. on 9psi, it made 460/485 to the wheels through a 60e
Old Oct 21, 2013 | 02:01 AM
gamble686's Avatar
Was it Mitch that had 4.10s in his twin turbo 5.3 that got into the 10s?
Old Oct 21, 2013 | 04:50 AM
Id say 3.42's if you want to change, maybe 3.73's but 4.10/4.11 is too much
Gadgetized
Aug 21, 2020 03:14 PM
JordanH
Aug 8, 2015 07:59 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
Gadgetized
Jul 18, 2015 02:15 PM
