Turning up the boost
Old Oct 13, 2012 | 08:00 PM
TRD_Tundra's Avatar
Default Turning up the boost
Well finally got my Silverado back last weekend, tuned by Tellez Motorsports.
First it was running on 5#'s for the first 2 days, then upped the boost when I got my AEM TruBoost hooked up and turned up the boost to 7#'s(peaks 8).
Thing is I want more boost.
My Tuner is coming back in 2 days, and plan on re-tuning it for 10-12#'s on pump gas. Do you guys recommend going that high quick?
Tuned for 93 octane
Stuff done so far
Stock 2006 5.3 W/ 101K miles
Stuff installed recently (less than 300 miles)
-Cam Lunati 216/220 .560/.560 @114 lsa (dual springs)
-Head studs
-LS9 Gaskets
-76mm .96ar Front mount intercooled turbo
-Bosch 60# injectors
-Aeromotive 340 intank fuel pump
-4l80e W/ stock stall
-Stock G80 W/ 3.23's(Horrible digs, 1st gear= 70mph 2nd=120)
And what kind of rwhp do you guys think it has on 8#'s of boost?
Old Oct 13, 2012 | 10:18 PM
patofdzb's Avatar
i reccomend you swap that 3.23 to a 3.42 at least.. or a 3.73
also, get a stall!
everything else sounds good, and you should have absolutely no problem at 10 - 12 pounds.. you´ll love it! i just went from 7 to 12 today..
Old Oct 14, 2012 | 12:52 AM
idahoblkss's Avatar
man out of the hole with that gearing and the 80e must be horrible . i would gear up that would make a huge difference.
Old Oct 14, 2012 | 03:57 PM
ZO6Ted's Avatar
3.42's to 4.10's dropped me .74 in the 1/8th with 32" tires. It was a total pig before.
Old Oct 14, 2012 | 04:08 PM
La SS's Avatar
At least get a converter to put you into boost maybe then digs wouldn't be horrible
Old Oct 14, 2012 | 04:38 PM
Llaverito's Avatar
Some 4.10s will turn the truck into a completly different beast
Old Oct 14, 2012 | 05:59 PM
TRD_Tundra's Avatar
I'm leaning into 3.73's better, I read that boost likes long gears.
Old Oct 14, 2012 | 06:28 PM
patofdzb's Avatar
boost does like longer gears, go with 3.73s... i HAD 4.11´s in mine and i swapped them back to 3.73´s 3 days ago..
Old Oct 16, 2012 | 05:11 PM
TRD_Tundra's Avatar
Nvm. Going w/ 4.10's
Old Oct 16, 2012 | 10:22 PM
ZO6Ted's Avatar
Great choice. Now consider a better stall when you can. Your gonna love it though!
