Turbo: where to put o2 sensors
Old Mar 3, 2013 | 11:08 AM
custom 68's Avatar
Default Turbo: where to put o2 sensors
I have a question on best placement for 02 sensors. I have the kbracing log manifold (im pretty sure) so I have my stock drivers side manifold with the 02 sensor there. I have my wideband in the lower cross over. I have a spot in my down pipe or a spot right before the turbo in the merge part of the log manifold. So should I leave the wideband where it is? and should the narrow band go before or after the turbo?
Old Mar 3, 2013 | 11:19 AM
Atomic's Avatar
I have a gauge for that
Narrowband can be before on the correct side. Wideband needs to be after the turbo in the downpipe.
Old Mar 3, 2013 | 11:23 AM
custom 68's Avatar
alright, I will do some swapping around. I was fighting some issues and ended I needed to swap to a 2 bar tune I was getting bad readings on from my MAF it is now removed and I was trying to do it all correct. I moved them all over thinking that was my issue. I will put them back and get this going.
gmcyukon
Oct 5, 2015 06:20 AM
JordanH
Oct 3, 2015 03:59 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Pimpinpete
Sep 8, 2015 07:39 PM
