Turbo for towing???
I just bought a Trick hot parts setup with FMIC and 3.5" DP to go on my 5.3 this summer. I have been doing quite a bit of reading and have somewhat decided on a MP T70 for the turbo. My question is, with the .96 a/r housing, how often will I be building boost when towing a load? I pull around 4000lbs for 4-5 highway hours fairly often, and occasionally heavier loads. I realize when I pull a hill or pass that the turbo will spool, but will it be building boost when I'm just cruising around 75mph @ 2300rpm's? What do I need to be aware of when towing for several hours at a time with a turbo? Should I get a different sized turbo to prevent it from spooling in this situation? I have never had any type of boost before so I'm new to this game. Just want to make the best possible decision in choosing which turbo will suit my needs the best. Thanks in advance.
Tyler
Tyler
I don't want to be towing under boost. I want to know what I need to do to keep my truck out of boost under these conditions, or if it's even possible. If it means getting a T-76 to make it spool later then so be it. Regardless, I don't want my engine under those condition's for hours upon hours at a time. I towed for 12+ hours at 70+mph last weekend for example lol.
GFYS and STFU
You won't be under boost the whole time. I've towed a 9,000 lbs boat 5 hours and a 4,000 lbs trailer for quite a year and a half with my STS and while cruising you won't be in boost.
http://www.youtube.com/watch?v=iHCX4IwqtUw
Boost while towing is COMPLETELY up to you and how hard you press on the gas. If it's making boost, it's because your pushing the pedal down enough to make it. If you don't want boost let up on the gas. Towing takes power, boost makes power, your foot controls BOTH!
. How hard you want it to pull= how much throttle you give it.
I've towed plenty with my truck with every turbo from a MP T70 .68 a/r to a BW S480 1.10 a/r.
You want your converter locked at highway speed, just like normal, or you will make a TON of heat in the tranny. Once again, boost is not created by RPM, turbo size, engine size or any of that alone. It is created by load, and load is created by the weight your trying to move, and the amount of throttle you give it. Towing is not a problem with a turbo for any distance. I've towed 5000lbs from AZ to WY (1200 miles) many times with my turboed truck.
You control the boost, it's not just there cuz you are towing or at a certain rpm. Once you drive a turboed truck, you will know what I mean. You get boost by giving it more gas, you don't want to be in boost, let off the go peddle a little,
The boost gauge goes up and down with your right foot, nothing else. Just because boost/power is available, doesn't meant you have to use it.
0psi of vac/boost on the gauge is about the same power for that RPM as if you didn't have a turbo and were running the truck wide open throttle. A turbo just let you go beyond that power IF you want to.
You should never pull a heavy load in overdrive. You will want a .96 or larger a/r. One thing your torque curve will be completely different so you will be able to pull more easily. Egt is a must if your pulling. If you notice your egt going up and air fuel is fine just pull back on the throttle.
With a good tune and good foot controll you should have not problems.
