Turbo setup for drivability (hills/altitude)
Old Jul 30, 2009 | 01:05 AM
2001CamaroGuy's Avatar
Default Turbo setup for drivability (hills/altitude)
I live in Phoenix (~2000ft) and around town my tahoe works fine (not looking to "hot rod" it). Last weekend however, I went on a day trip to Flagstaff (~7000ft) since I'm looking seriously at transferring up there for my masters. Understandably the higher in altitude I went, the worse performance became. The vehicle has 4.56 gears (32" tires) but it was often hard to even maintain 75mph on many of the hills (5-7% grades) without downshifting and even then acceleration was painful. By the time I was driving home that evening, I was dead set on a turbo.
I don't see a need for more than 5-7psi since my objective it really to maintain HP/performance, not add (though I won't complain..... ). Also simplicity/maintainability/lifespan/cost are of high importance. I don't like rear mounts (turbos belong up front near the heat source) so they are not an option. My first "choice" is usually small-er twins (one on each bank) but since I'm looking more to maintain HP under steady state conditions (not fast tip in response), a single large would provide a lower air charge temp and more capacity overall (correct?). If possible, I would LIKE to avoid adding a cooler (at least initially), but I'm not sure that is really feasible.
How to go about it?
Old Jul 30, 2009 | 02:45 PM
WJ MARK's Avatar
I live up in the clouds also. Turbo's work much better at altitude then superchargers. Go for it! Give Trick a call and he'll hook you up with a great setup!
Old Jul 30, 2009 | 06:10 PM
charcold-bowtie's Avatar
i agree with him. Even my little 4.8 never downshifts. and I it pulls really gooded 4th gear TC locked at 70 too.
Old Jul 30, 2009 | 06:20 PM
kbracing96's Avatar
I've made that drive several times, don't recall my truck down shifting much, even with the 4.8 and t60 turbo unless I "needed" to pass some one . I think my base kit would work well for you.
Ls3silverado
Jul 31, 2015 04:22 PM
iregret
Jul 27, 2015 10:32 PM
oharajo
Jul 18, 2015 09:24 PM
Aboss
Jul 9, 2015 10:28 AM
