turbo and sc MPG
I think the turbo will do better than the Radix type blower with a bypass. The bypass is open when you are cruising, the blower doesn't assist any air into the engine. The turbo always gives some sort of assistance once it gets loaded even a little bit. You don't have to be in boost for the turbo to move air. The blower needs to close the bypass valve before it starts to move air.
Ive had my truck turboed for over two years now. And with my driving habits ive never seen better than 14 MPG in town it never sees the highway so i cant help you out there its not my dd either. In two years ive only put 6k miles on the truck.
I lost 1~1.5 mpg hwy after my last mod, the Radix. Went from 18 mpg with all mods in sig. (accept Radix) to 16.5~17 hwy cruising after Radix install. I didn't add the Radix for mpg concerns but the trade off in added power more than makes up for the drop in fuel economy.
I'm not going to say one is better than the other, I just *think* the turbo has a better shot at mpg out of boost. Don't choose one or the other based on this. Ride in both if you have the chance and pick based on power delivery and make sure you will be able to meet your goals.
I can see what yall saying. I love turbo bec can adjust more boost what I want
Hey Trever1t Is your sc radix correct. IS there anywhere I can see or explain me to compare radix, procharged, Magnacharger, kennel bell or whipple. I am curious which is better for supercharged? I thought its procharged or kennel bell (KB have 2.8 bored) not sure.
With the bypass open you are circulating the air while spinning the inertial load of the rotors. Say you have a backpressure of 5,10, or 15psi at low load levels with a turbo, this is overcome by 100+psi exhaust pressure exiting the cylinder. You loose some in both cases, but once you start spinning the turbo it is able to make up the loss before you go into boost.
