Turbo rods
Old May 20, 2010 | 10:13 PM
HIPSI's Avatar
Default Turbo rods
Whats everyone using for rods on there F I Motors? Are the H beam callies enough?
Old May 20, 2010 | 10:32 PM
bansheerider44's Avatar
not sure of your power goals or build specs but the H beam callies are great rods. I have the cheaper Eagle H beams and are holding strong.
Old May 20, 2010 | 10:33 PM
Dewey's Avatar
IMO any forged H-Beam rod would perform well in an FI setup.
Old May 20, 2010 | 10:39 PM
HIPSI's Avatar
I'm looking at building a 6 oh with 76mm turbo with atleast 10 psi min.I wanna do it right the first time so if you guys don't think the H beam will hold i'll go with the I beam.
Old May 21, 2010 | 11:43 AM
joeyc125's Avatar
11 Second Truck Club
I beams are weaker than H beams
Old May 21, 2010 | 12:21 PM
HIPSI's Avatar
Then why do they cost 200$ more than H beams?
Callies I-Beam Connecting Rods 6.125" $750.00
Click to enlarge
HD Series Connecting Rods
Compstar Heavy Duty connecting rods are built for high horsepower, high RPM, big displacement engines. Numerous design features found only on more expensive custom connecting rods have been incorporated into the Compstar HD Rod.As demanded by their High Value design criteria, Compstar engineers carefully examined every square millimeter of these components, leaving nothing to chance. See for yourself :
* Increased material at 45 degrees to the tower in the commonly weak shoulder area
* Parting line footprint increased by 23% provides greater housing bore stability
* Contoured tower flanges and pin end housing
* Added material strengthening the pin collar
* Available with 7/16 diameter ARP L19 cap screws
* Robust cap featuring twin-rib design
Old May 21, 2010 | 12:40 PM
03chevyroyce's Avatar
lighter maybe?
Old May 21, 2010 | 12:51 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Are you currently building an engine or are you thinking of tearing into yours and swapping rods? I run stock.
Old May 21, 2010 | 01:04 PM
kbracing96's Avatar
H beams are stronger but heaver then I beams. As far as pricing, it just depends on the company. Scat I beams are cheaper then their H beams.
I'm running Scat I beams cuz they were the cheapest forged rods I could find and a step over stock rods, and only about $280. For your goals, a stock rod will work fine for only 10 psi in a 6L.
Old May 21, 2010 | 01:47 PM
HIPSI's Avatar
Building one
