Turbo Question..
Old Feb 6, 2012 | 09:14 PM
wld1985's Avatar
Default Turbo Question..
Alright ive been wanting to turbo my 4.8 GMC..I have been looking at the turbo kits and looking at the Trick Hot pip kit...My question is, what is the cross over pipe for? One is the manifold the other is the down pipe for the turbo... The crossover hooks up to what? I've got true duals now,2 mufflers x-pipe yadda yadda...So what does the x-pipe they have hook up too? Or should i Just buy the manifold and get my turbo and go from there..
Stage 1 Hotpipe kit.
Old Feb 6, 2012 | 09:42 PM
TXjeepTJ's Avatar
manifold replaces passenger side manifold, then the cross over pipe connects to the drivers side stock manifold. So you have the flow from drivers side and passenger side flowing through the turbo
Old Feb 6, 2012 | 09:49 PM
TXjeepTJ's Avatar
Here you can see the crossover pipe
wld1985's Avatar
I knew the manifold replaces passenger side..But damn..So then my true dual is only one exhaust after it's all said and done... I dont like that,due to the fact i've spent a good bit of money on that exhaust setup..
Old Feb 6, 2012 | 09:52 PM
TXjeepTJ's Avatar
yeah, that does suck. You could always sell it
Old Feb 7, 2012 | 12:26 AM
black04's Avatar
twin turbos
Old Feb 7, 2012 | 12:37 AM
sprayedenali's Avatar
if you think your true dual exhaust cost alot just wait until you go FI..... then youll start to learn what "cost alot" means
Old Feb 7, 2012 | 04:46 AM
mad max 777's Avatar
^^^ lmao so true !
Old Feb 7, 2012 | 06:37 AM
wld1985's Avatar
Black not looking for that kind of power right now....
Spray, I guess the good way to look at it is I've had it for long enuff I guess it paid for itself now...
Old Feb 7, 2012 | 09:00 PM
wld1985's Avatar
Well somehow last night I ran across adeal,and found a Trick Performance set up with hot pipes and New Turbo for pretty cheap... I picked bought it,so I guess I will soon be installing the turbo setup after I get everything in order..
