turbo plus nitrous.
Old Aug 1, 2011 | 04:43 PM
Sweetser54's Avatar
Question turbo plus nitrous.
who all runs turbo and nitrous on the same vehicle? i am thinking about putting 100 shot on my silverado and was wondering if u guys had and tips for me. i know i have to add another fuel pump. im running 10lbs of boost. 78mm turbo on a 6.0 i want to add a shot if nos to get it off the line any tips would help. thanks so much. sorry if i left out anything. i use Hp tuners.
i hope it ok to post this here. thanks for your help
Old Aug 1, 2011 | 04:44 PM
Sweetser54's Avatar
im wondering how much if any that i need to change my tune? what about fuel pressure? im about 58psi do i need to lower it any?
Old Aug 1, 2011 | 05:33 PM
kazfan30's Avatar
Depends on a wet or dry shot... some guys run small shot to spool Turbo and cool air a lot.. 30-50 shot. You can do what some do to leave out harder... hook up nitrous off of a pressure switch..Hobbs or a Meth activation switch.. set it at around 4 Psi. You leave on spray via wot switch and as soon as boost hits 4 psi nitrous cuts off...boost takes over. Timing will be the only concern on the kit...
Old Aug 7, 2011 | 08:20 PM
00rcsb's Avatar
In for information on this as well. I was thinking 100-125 hp dry in front of the 76mm turbo lq4 when we finish putting it together
Old Aug 7, 2011 | 09:06 PM
TrickTurbo's Avatar
Truck Sponsor
Wet shot will cause no to little tuning change.
100shot off the line will help a huge amount.
Like recommend already.
Come off the shrader valve and use a Hobbs switch to shut the unit down at X psi.
You will need to wire it up so at
x psi
non wot
non arm the system won't fire.
Old Aug 8, 2011 | 01:48 PM
kbracing96's Avatar
x psi
non wot
That's how mine is. Arm switch powers the WOT switch, which then goes though the pressure switch set to turn it off at 9psi and then to the relay that turns the noid on and off.
Just wish that somebody who I got the noids from (^^^ this guy, Rick... ) hadn't used loctight on the purge plug so I could not get it out to put a purge noid on it...
Old Aug 8, 2011 | 01:54 PM
slowec's Avatar
I am thinking I'll just spray a 35 dry to my pig rich 10.5 a/f sd tune, and let er eat. Worked great on my Z28.
Old Aug 8, 2011 | 03:08 PM
TrickTurbo's Avatar
Truck Sponsor
Really a simple plug is stopping you.
drill it out and retap. Seeing how u didn't use heat to remove the plug.
Old Aug 8, 2011 | 05:44 PM
kbracing96's Avatar
I was in a hurry... some stock dude in a slow white truck was begging me to come watch him get kicked out of another track! lol
Old Aug 8, 2011 | 08:13 PM
slowec's Avatar
tell him to come to the truck shootout in Ga where they let a Lightning run 8's with NO cage last year.
STSRACE.COM
