turbo part wiring
ive been looking threw some threads and have some questions about wiring, map sensor boost controller meth kit and boost gauge all come with one plus the one built into my truck, how do I consolidate or wire or what. im lost.
also boost manifold block. one I got from godspeed has a 1/2 inch in or 5/8 in and a plug on the other side I was thinking of running break booster into one side then out the other directly into the intake and running my boost reference ports off the manifold. would that work or too much variences when hitting the breaks to not make it worth it.
The MAP sensor should be plug and play with the factory connector
As for the boost controller if this is your first build id get the truck all set up and working first before you use a boost controller, just run it on the wastegate spring
Im no help with a meth kit sorry
A boost gauge is simple, run the little plastic tube to a boost source and then theres a pos and neg for the back lighting
I would keep your booster hooked up to the factory port on the manifold and feed that manifold block off the old PCV port on the top of the intake
It did what I was getting at is I didn't want to have 3 different map sensors I didn't know if there was a way to consolidate or a jumper harness or what not. I hate wiring sometimes
5.3lSilverado
25
Aug 29, 2016 12:48 AM
