Turbo oil drain
Old Feb 5, 2011 | 06:39 PM
Mangled03gmc's Avatar
Baltimore Whore
If you are running a front mount, drain it right back into the timing chain cover..
Old Feb 6, 2011 | 09:40 AM
OnyxSilveradoSS's Avatar
pics going into the timing cover please.
Old Feb 6, 2011 | 03:24 PM
Spoolin's Avatar
GFYS and STFU
Originally Posted by 02'Z71ONDUBZ'
Is your motor out of the truck? I just tapped the front of the pan with a - 10 fitting right below the crank pulley. It's tapped with a tapered NPT thread, the fitting will never leak.
This...
Old Feb 6, 2011 | 09:30 PM
kalikid06's Avatar
Yes, the engine is on a stand.
Old Feb 7, 2011 | 05:02 PM
Swerve7rpm2000's Avatar
Timing chain cover, as u can tell in my particular year model truck the drain on the left wouldnt work due to clearence issues, npt threaded and jb weld!
Old Feb 7, 2011 | 06:15 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
what about this spot???
Old Feb 7, 2011 | 06:36 PM
Atomic's Avatar
I have a gauge for that
Mine is right below the starter.
Old Feb 7, 2011 | 11:04 PM
Bill Reid's Avatar
Originally Posted by 2toneblown
Bill why did you go -12? I haven't seen anything larger than -10
Because typical T4 frame based turbo's have a 3/4" ID exit from the bottom of the center section. -12 is 3/4" ID. I elected to not step it down. I am a little sensitive to turbo drains considering what I went through installing gravity drain based TT kits on C5's. Granted front mount truck turbo's are typically mounted higher so gravity and their proximity to the pan allow more options. The -12 move was to prevent the question ever arising again if I have a turbo smoking problem or oil winding up in the charge section. I also do not have any 90 degree bends in my drain. It's one less variable to factor into any pontential future troubleshooting.
Old Feb 7, 2011 | 11:16 PM
stock48's Avatar
9 Second Truck Club
Mine is on the bottom front part of the pan. Has a 90* 1/2
x 3/8 pipe 90* elbow threaded into pan. Have ran this setup for years with no prob. Doesn't fit 2wd's so good tho I hear.
Old Feb 8, 2011 | 07:51 AM
Rick_Vor's Avatar
I just did a couple 3/8" NPT taps into the front of my oil pan. 5/8" (-AN10) hose fits perfectly over the 3/8" pipe.
Rick
