Turbo oil drain
Like the title says, where is the best place to put a turbo oil drain on the oil pan. I was thinking right above the oil level sensor and as high as a I can mount it on the pan. Thoughts?
I'm going front mount pretty soon so I can't use the oil cap. I thought about putting the drain in front of the pan but will it drain very well when the truck is on a downward slope? A steep driveway for example?
Is your motor out of the truck? I just tapped the front of the pan with a - 10 fitting right below the crank pulley. It's tapped with a tapered NPT thread, the fitting will never leak.
