turbo muffler options
Old Mar 4, 2013 | 08:19 PM
javzh's Avatar
Default turbo muffler options
what are you turboed guys running exhaust wise? i want mine to be pretty quiet.
i have a 6.2 muffler laying around but kinda on the ropes on installing it.
will it be too restrictive ?
i also have a e-cutout i could install.
i plan on running 3.5" since thats what the downpipe is. so might as well run it all like that.
Old Mar 5, 2013 | 08:16 AM
boostedsl2's Avatar
You want straight through with turbo, the bigger the better. Any reduction in back pressure is going to help. I will tell you that the bullet type race mufflers do absolutely nothing for sound. I usually use magniflow on everything and they work great. Vibrant aluminum mufflers are ok.... perforation on those is a pipe with holes drilled in it lol.
I want something a little more quite too. I intend on running the wastegates open air, so i'll have plenty of noise when i'm on it. I'm currently looking for a muffler for my setup. I found this 4" muffler on summit. Not sure if i can even fit this bad boy lol
Diamond Eye Performance Exhaust Mufflers 460002 - SummitRacing.com
Anyone every use this thing?
Old Mar 5, 2013 | 09:04 AM
nonnieselman's Avatar
im running the stock catback on mine. it works good for low boost and towing/DD..
Open the cutout and the boost goes too high
Old Mar 5, 2013 | 12:14 PM
M&M Turbochargers's Avatar
you might check out "Pypes" mufflers also
Old Mar 5, 2013 | 01:53 PM
javzh's Avatar
What is Considered low boost? Im going to start at 10lbs of boost
How much in boost increase did you see with cutout open. I wouldn't want to open the cutout and cause any damage.
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
Suburban2500
Jul 13, 2015 09:57 AM
lxcoupe
14
Jul 9, 2015 09:15 PM
