Turbo LSX 2011 Escalade EXT build
#102
#105
It's more than likely flooding it in. Gain **** on the dash should be half way. Inside the controller under the cover are 2 dials, adjust them so it turns on at say 5 psi and start the ramp rate out slow and go from there.
#106
Water doesn't burn, I have good results on 100% meth.
Here's a handy lambda chart.
Alcohol--- Lambda---- Gas
6.4 ---- 1 ---- 14.7
6.2 ---- 0.96875---- 14.240625
6 ---- 0.9375----- 13.78125
5.8 ; ---- 0.90625 ----13.321875
5.6 ---- 0.875----- 12.8625
5.5 ---- 0.859375 -----12.6328125
5.4 ---- 0.84375---- 12.403125
5.2 ---- 0.8125----- 11.94375
5 ----0.78125----- 11.484375
4.8---- 0.75----- 11.025
4.6 ----0.71875---- 10.565625
4.5 ----0.703125---- 10.3359375
4.4---- 0.6875 -----10.10625
4.2---- 0.65625---- 9.646875
4---0.625---- 9.1875
3.8--- 0.59375---- 8.728125
3.6---- 0.5625---- 8.26875
3.5---- 0.546875 ----8.0390625
3.4---- 0.53125---- 7.809375
3.2---- 0.5---- 7.35
#109
On just pump gas I made a little more peak horsepower but with the meth going I made a lot more average horsepower. We didn't spend a whole lot of time because I hadn't changed much since the last dyno tune, about 4 pulls. I walked away with 552.7rwhp and 575tq with an average rwhp of 403 from 2000 to 5800 rpm.
#110
Checked on kit and nothing was setup on it. So when we used it on dyno must have been dumping to much without the settings made on it. So that sucks. Anyway we got the Autotrac TC swapped out put in AWD TC and front driveshaft back in. Put on a ground strap from alt bracket to block. Had problems with ground since bracket was powdercoated.
Got to block off the recirculate port on crossover of wastegate. Install DJM end links on rear swaybar. Get trans tune file back from Circle-D and do road tune.
