turbo lq9 need help
Old Mar 11, 2010 | 09:21 PM
elmore57's Avatar
Default turbo lq9 need help
hey everyone i am new to this but i am looking to turbo my 2005 ss silverado it is a high compression motor but im trying to figure out what a safe boost pressure would be with a stock fuel system thanks cody
Old Mar 11, 2010 | 11:28 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
on my stock 03 fuel pump (with 42lb/hr injectors) I ran 10psi with 100% meth injection and no issues (tuning required). I pushed to 12psi and was out of fuel pump.
The only real answer to your question, however, is the amount that doesn't cause detonation. Your ambient temps, fuel quality, and tune will dictate your max safe psi just as much as the compression.
Old Mar 11, 2010 | 11:55 PM
LsxCody's Avatar
if your gonna go thru the trouble and money to boost your truck, you might as well upgrade the fuel system.
Old Mar 12, 2010 | 12:03 PM
elmore57's Avatar
the only reason i tring to not upgrade is with no return line i would have to do twins in tank or swap fuel system to a 04 down i think then upgrade and with 10:1 compression ive herd 5lbs would be about it. on a daily driver and be safe
Old Mar 12, 2010 | 02:00 PM
I AM A MOTHERF*CKER
Mine was a DD and in Florida heat, and like I said I ran 10psi with no issues (its all about tuning). However, like I said it had meth injection for intercooling. I also had a return-style system.
You're not talking about leaving the stock injectors in it, surely? Will this be intercooled at all?
You could always put a single walbro 255 in tank in and be better off than the stocker (which is a 190 lph if memory serves).
Old Mar 12, 2010 | 05:47 PM
elmore57's Avatar
well im in texas so there will be heat i am using a air to air intercooler its like 27x12x3 i think and ive talked to a few companys and i havent seen a single 255 offerd for a non return system thats why everyone trys to sell me twin in tanks witch is overkill for my goals will stock injectoer support any boost and if not would 42 be enuff who did your tune sorry for all the question you the first helpfull person i found thanks
Old Mar 12, 2010 | 06:29 PM
thunderwagen's Avatar
I ran my LQ9 at 11# with my Turbo setup no problem. That was on my 05 vho which was also returnless. I had a single walbro 255 in tank pump that came with my magnacharger. It was making 68# of fuel pressure normally and at full boost dropped to 64#. I ran that boost level with 60# injectors with a lot of room left on the injectors. I maxed the 42# injectors at 8# of boost. The 255 probably wouldn't have gone much further on its own, but 11# was a lot of fun.
Old Mar 12, 2010 | 07:43 PM
Sleeper04's Avatar
You can run a Walbro on a returnless system without any issues. I've been running one for the past 3 years. I'd get 60# injectors and a Walbro for sure. Meth injection to help keep detonation in check.
Old Mar 12, 2010 | 09:24 PM
I AM A MOTHERF*CKER
Stock injectors + any boost =
Old Mar 13, 2010 | 06:36 AM
OnyxSilveradoSS's Avatar
you could look for an e85/flex fuel pump. they are drop in and can push alot more HP than people thought.
I ddont think adding a return line would be too hard, you will have other plumbing to do with a turbo so this would be one more thing.
Aug 24, 2015 08:14 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
The_W
Aug 15, 2015 08:07 AM
Aboss
Aug 11, 2015 09:05 AM
Denali08
Aug 9, 2015 04:34 PM
