Turbo LQ4 questions
Old Jun 22, 2021 | 08:20 AM
flycole's Avatar
Originally Posted by shakenfake
Wait so now it is a 68mm?
03sierra doesn't an s480 have like a 96mm turbine?
someone was telling me it’s a 98mm extruder and 68mm on the intake
Old Jun 22, 2021 | 09:10 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Ah yes I saw that now.
Also 03sierra I'm retarded pretty sure s480 is 80mm
Old Jun 22, 2021 | 09:42 AM
03sierraslt's Avatar
An S480 is an 80mm compressor inducer, the turbine varies, typically a S480 has a turbine inducer that’s 96mm,92mm or 87mm. An 96mm turbine is 96mm inducer and 88mm exducer. For example I have the following.
S480/92 1.25 T6 80mm compressor/92mm turbine inducer/ 1.25 AR Housing/ T6 flange.
S485/96 1.32 T6 85mm compressor/96mm turbine inducer/1.32 AR Housing / T6 flange.
on a compressor the inducer is what you see, think compressor inducer is air in, compressor exducer is air out.
On a turbine the inducer is where the hot exhaust gas hits first and the exducer is the part of the turbine wheel closest to the downpipe.
Old Jun 22, 2021 | 09:51 AM
flycole's Avatar
so what do you guys recommend as far as the turbo/pistons?
Old Jun 22, 2021 | 10:03 AM
Stock pistons and something in the 76/75 or 78/75 range. For your goals you don’t need a S400 frame.
TrickTurbo
Jun 24, 2019 10:49 AM
TIM Z
May 21, 2012 08:04 PM
1SlowHoe
Jun 1, 2011 09:02 PM
AceHaag
Mar 18, 2008 10:59 PM
