turbo heat blankets
Old Jan 19, 2015 | 10:30 PM
LPCWS6's Avatar
Default turbo heat blankets
Do they all have fiberglass looking stuff that goes everywhere in the air when you touch them?
Old Jan 19, 2015 | 11:34 PM
Jake75's Avatar
mine does but figured it was because it was a cheap one from amazon
Old Jan 20, 2015 | 12:09 AM
08DenaliT's Avatar
My comp turbo ones don't come apart and are super sturdy but will see after a few heat cycles. I don't think the dei ti lr tech ones don't but could be wrong
Old Jan 20, 2015 | 02:56 AM
sTNT971's Avatar
I'm using pTp blanket T3-T4 its fiberglass (1800 degree F)
also i was using titanium PTP (2000degree F)
now I have order custom blanket with custom logo from Aero Flower performance its fiber glass but the look its like carbon fiber
all this blanket really good
Old Jan 20, 2015 | 07:37 AM
blownescalade62's Avatar
I use the same PTP large T4 blanket not cheap but well made will not degrade like the cheap blankets.
Old Jan 20, 2015 | 10:11 AM
Atomic's Avatar
I have a gauge for that
I have used basically every blanket on the market and they all degrade eventually. My setup was considerably hotter than most though, so that might have something to do with it.
Old Jan 20, 2015 | 02:22 PM
GMCtrk's Avatar
Fiberglass shouldn't be going everywhere, it should be contained within the covering of the blanket both on the outside and inside. Otherwise it may be defective.
Old Jan 20, 2015 | 03:31 PM
Atomic's Avatar
Mine always fry on the rear edge between the blanket and the stitching.
Old Jan 20, 2015 | 03:43 PM
Ptp blankets have High heat resistance Kevlar stitching.
Old Jan 20, 2015 | 03:51 PM
GMCtrk's Avatar
As you mentioned, you probably exceeded the blankets thermal limit. I'm using that shitty ebay brown "T6" blanket (that barely fits the T4) and haven't had any issues with it for over 2 years now.
