turbo guys: IAT's
Old Dec 9, 2008 | 09:19 AM
sureshot's Avatar
Default turbo guys: IAT's
I know IAT's are alot higher with the Radix setup compared to the centrifigual blowers (Procharger). I was wondering if IAT's are an issue with intercooled turbo setups?
Old Dec 9, 2008 | 09:35 AM
thunder550's Avatar
High on diesel fumes
I saw mine rise from 87 to about 120 at the track last weekend running at 15 psi.
Old Dec 9, 2008 | 12:12 PM
bud8fan's Avatar
mine rises about 20 deg above ambient now since i went to a bigger turbo
Old Dec 9, 2008 | 01:36 PM
hellbents10's Avatar
LS1Tech Sponsor
Most of the air to air turbo setups we do end up about 20-25 degrees over ambient at the end of a run. Or less then ambient by 20 degrees with meth!
A2W, depends on weather or not you have ice.
Old Dec 9, 2008 | 03:26 PM
charcold-bowtie's Avatar
easy driving mine runs at about 10 degrees over ambient. After a 1/4 pass It probly rises to around 35 degrees over ambient.
Old Dec 9, 2008 | 08:50 PM
silver-mod-o's Avatar
Hunt&Fisherator
Reg driving, its about 5-6 over ambient, end of a run sees 15 degrees over... Air/air T-70 at 6psi.
Old Dec 9, 2008 | 08:53 PM
nonnieselman's Avatar
my put together W/A setup hasnt ever given me a problem but with only 5# on a STS setup..
They rise a lil but nothing to even worry about, even when towing.
Old Dec 11, 2008 | 07:58 PM
2ktransam's Avatar
Mine runs about 3-4 degrees above ambient when cruising around and at ambient or lower at 13psi with the meth.
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
GMCtrk
Dec 18, 2015 04:47 PM
chvy=power
Sep 8, 2015 11:06 AM
slowswb
Sep 5, 2015 02:27 PM
