Turbo Guys.. Boost Gauge ?
I tried to search this but came up with no results... hooking up my boost gauge and obviously i need to tap into the manifold somewhere past the T-body but looking for some ideas on where you guys tapped into and how you did it to get your readings??
Still running the truck intake? There is a port on the passenger side towards the top of the intake, plastic engine cover will be covering view. There is a plastic tab cover the port that will need to be removed in order to use.
yep i got one of these...run the line from the intake to this and run all other lines from this block to everything else like blow off valve,wastegate and boost guage:
http://www.full-race.com/catalog/pro...oducts_id=1104
