Turbo general information thread
Old Jul 15, 2008 | 05:19 PM
  #51
parish8's Avatar
single digit dreamer
Red face
Originally Posted by Wilde Racing
You know my plan, I'm going to use the EGR harness for my 5v supply.... Did you (parish) ever log backpressure in your truck?
yes. thats what we are talking about >> https://ls1tech.com/forums/showthread.php?t=264718
Old Jul 15, 2008 | 05:25 PM
  #52
Wilde Racing's Avatar
How do I change this text
I'm a dumb ***, I read both your other links, but missed that one....
Old Jul 15, 2008 | 08:15 PM
  #53
Spoolin's Avatar
GFYS and STFU
Hey Jim sorry if this is a stupid question but were you seeing 3lbs of boost for every 1 lb of restriction in the hot side, am I understanding that right?
So if your pushing 15 psi your most likely seeing 5 psi in the manifolds? I was under the impression that it was a pound of restriction for every pound of boost produced.
And someone in your tech thread mentioned that 2:1 ratio is better, why would you want more restriction per lb of boost? I'm probably bot understanding this right, and the fact that my computer screen won't allow me to fully see/read the graph properly is probably hurting my comprehension.
Old Jul 15, 2008 | 08:27 PM
  #54
vanillagorilla's Avatar
He means for every pound of boost you see 3lbs in the exhaust pre-turbo. His ratio was 3:1 meaning three times the amount of pressure on the exhaust side vs. the intake. 2:1 doesn't necessarily mean less boost, but less exhaust pressure. Some ways to lower exhaust pressure are a bigger dp, bigger a/r housing, better flowing pipes. Turbine wheel design has a lot to do with it too. Not all are created equal. This just shows why cams with little to no overlap tend to do better with turbos.
Old Jul 15, 2008 | 08:41 PM
  #55
Spoolin's Avatar
GFYS and STFU
Yeah it made more sense to me too but his thread topic was
anyone ever log boost/exhaust presure ratio? check it out.
Which to me tells me for every 3 lbs of boost he saw 1 lbs of exhaust. "Exhaust pressure/boost" makes more sense to me too. Well in any case it's very informative because I was always curious as to what mine was in general, and I'm sure it's worse than 3:1.
  #56
Stoichiometric's Avatar
Yup, 5lbs in the intake and 15lbs in the exhaust. The pressure differential is sort of a measure of efficiency at a certain point.
Old Jul 15, 2008 | 08:45 PM
  #57
Spoolin's Avatar
GFYS and STFU
Hey Henry, where's the best place to put a sensor on our set-ups? Back by the turbo or at the "Y"? I'd like to see the pressure differential too.
Old Jul 15, 2008 | 08:50 PM
  #58
I would stick it anywhere after the Y pipe by 6" or so.
  #59
Spoolin's Avatar
GFYS and STFU
You first!
Old Jul 16, 2008 | 09:06 AM
  #60
t_thall's Avatar
3:1 sounds like a pile of backpressure doesn't it? I thought that most setups will run close to 1:1
