turbo cams
Old Dec 14, 2008 | 10:30 PM
sharpshooter's Avatar
Parish- would you run stock length push rods with the 02 Z06 cam? I never get a good answer to this ?.
While we are swapping the cam we will put in hardend push rods.
Old Dec 14, 2008 | 10:45 PM
Mangled03gmc's Avatar
Baltimore Whore
I have read that you can go either way with it.... But that still doesn't answer your question LOL.. This should be good when it is done, you guys will have identical set ups, only 1 will have a turbo... I will be waiting
John
Old Dec 14, 2008 | 10:53 PM
sureshot's Avatar
John
Yeah, hopefully I'll be able to hang with you supercharged guys
Old Dec 14, 2008 | 10:59 PM
silver-mod-o's Avatar
Hunt&Fisherator
You shouldn't have any problems with those guys if its set up properly
Old Dec 14, 2008 | 11:00 PM
sureshot's Avatar
Hopefully. In the end, I would just like to have a 12 second truck
Old Dec 14, 2008 | 11:03 PM
here it is
Old Dec 14, 2008 | 11:04 PM
we'll see
sureshot's Avatar
Originally Posted by sharpshooter
here it is
I know it's not a very good pic. Have to get some better pics on here soon
Old Dec 14, 2008 | 11:33 PM
stock48's Avatar
9 Second Truck Club
Here is the full build:
truck looks like mine 6" lift with 33" tires
3.73 gears
2500-3000 stall
4L65E
Trick turbo kit with FMIC
bosch in tank
60# injectors
Justin tuned
stock LQ4
317 heads
cam?
Parish- do you like the 01 or 02 Zo6 cam?If a budget isn't a big deal what cam would go for?
For a lifted truck with 3.73 gears I would keep duration @.050 below 220* @.050''. Something in the 206~to 215* @.050'', and 114~116* lobe center.
Old Dec 15, 2008 | 05:55 AM
parish8's Avatar
single digit dreamer
if your going to be buying hardend pushrods you might as well get the longer ones. that is if you have the 02 cam.
