Turbo Cam Help
Old Dec 12, 2010 | 06:36 PM
BigTone's Avatar
Default Turbo Cam Help
I am planning to run AFR heads twin 66mm turbos with alcohol injection. I need a good cam choice to get me close to mid 12s and am curious if anyone makes a turbo header kit for a 2002 Denali XL. What cams do you all have for me to choose from? Btw a lil overkill is alright.
Old Dec 12, 2010 | 06:41 PM
tarinitup's Avatar
9 Second Truck Club
the 226 230 in the for sale section should do good. You could also get one spec'd from Pat G. for $25 and get it right the first time.
Old Dec 12, 2010 | 07:08 PM
BigTone's Avatar
Sorry new to the truck and turbo thing. what would be the website for Pat G
Old Dec 12, 2010 | 07:25 PM
BigTone's Avatar
Also does anyone have a specific turbo recomendation? think the 66mms will serve my purpose i know what kinda power bigger turbos can achieve and that would be overkill for me. What brand and specs should I look for?
Old Dec 18, 2010 | 11:22 AM
07LTrquick's Avatar
You know, depending on what your going to do to your motor will really help determine the size turbo that you need.
There is a company in southern california that has specs. and made lots of cam's for this application (www.schneidercams.com) and can also take yours and make a regrind! they are great.
Gather some more information first before going to the turbo shop to buy a turbo. It will make all the difference in the end! All about the prep work!
Old Dec 18, 2010 | 04:20 PM
BigTone's Avatar
Callies crank BME rods and JE pistons. I am planning to run 2 88mm precision turbos with fron mout IC and alcohol injection. I am wanting to put out 1000+ hp top the wheels and still be streetable. The heads will be AFR LSX 245 heads and the engine will be bpred and stroked to 400 cubes.
greedygenius
Sep 3, 2015 06:51 AM
lxcoupe
Jul 27, 2015 08:19 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
black6spdz
Jul 16, 2015 01:32 AM
Atomic
Jul 11, 2015 03:51 PM
